Power Steering Pump leaking, what to do?
Old Jan 30, 2013 | 10:15 PM
adam699's Avatar
Default Power Steering Pump leaking, what to do?
Well I lost all my power steering fluid. Once I got the car on the lift I noticed that the fluid is coming out from the pump itself. I got the pump out and the gasket is a plastic rubbercoated thing and it appears that the rubber coating seperated from the plastic. I inspected the pump and everything on the inside looks nice and kosher; bearings are tight, shaft has no leak and no unusual wear. I have no means of checking the bypass valve but it doesn't look bad.
So, my question is, does anyone know what usually fails in those pumps? Do I just make a new gasket for it and see if that solves it?
Old Jan 31, 2013 | 12:40 AM
adam699's Avatar
Well, for the curious minds. I replaced the gasket and guess what, the same thing, but now I noticed that it also foams and shoots the fluid out of the PS reservoir.
I assume it's the pressure valve that is stuck and I have a re-manufactured pump on order.
Old Jan 31, 2013 | 05:29 AM
Sean B's Avatar
Adam, of course you've gone back to the rack and inspected the lines to and from the rack?
Old Jan 31, 2013 | 09:57 AM
dsnyder586's Avatar
I had the same problem on an XJ8 I owned- when I replaced the gasket it still leaked... very frustrating
rusty37
Apr 5, 2020 07:40 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
