Problems with antenna after extreme cold weather
Old Jan 30, 2012 | 03:20 PM
Estilian's Avatar
Default Problems with antenna after extreme cold weather
This morning we did have a new local record for low temperature - it was -26C degrees at 7:30 in the morning. I was afraid that the cat won't start, but it did... The problem is that the antenna didn't come out - it was covered with strong ice. I tried to clean it well before starting the engine, but my hands were burning of the cold so I was a little bit negligent.
I was pretty sure it will come out on the next start, but since then the antenna is not even trying to move.
Any ideas?! Is it possible that the electrical motor which is moving the antenna got broken only after one unsuccessful turn?!
Old Jan 30, 2012 | 04:15 PM
plums's Avatar
If the motor is fused, try checking the fuse. Motors draw the most current when they are stalled and you may have blown the fuse.
Another alternative is that there is something stripped in the gear to mast driving assembly as there is a plastic strip at the end of the mast.
Old Jan 30, 2012 | 07:15 PM
D. Fite's Avatar
Hope you get it working without too much trouble. I always keep my antenna mast clean by wiping in often with rubbing alcohol and then coating it with silicone lube or WD40. This helps keep it from freezing up if it gets some moisture in th mast sections. Just a thought hope it helps.
Dave
Old Jan 31, 2012 | 04:11 AM
JKo's Avatar
JKo
+1 for the WD40. I use it for both cleaning and lubricating the antenna. Mine had a tendency to not retract fully when temperature went below -5C. Didn't blow a fuse, and worked fine after a few hours in a warm garage.
Clean -> lube -> turn radio off -> turn radio on (and repeat a few times).
That won't of course help if the antenna is covered in ice...
Old Jan 31, 2012 | 10:52 AM
Estilian's Avatar
Thank you, both of you - D.Fite and JKo... I did lubricated the antenna with WD-40 and after good heating at the garage, now it's working as it should, even better
SD96XJ6L
Jan 12, 2022 04:30 AM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
