Purchasing a 2000 XJ8 w/ engine problem
Old Jul 10, 2011 | 04:56 PM
sparkenzap's Avatar
Can the rattle from chain tensioners be bad enough to cause someone to think that the engine is about gone?
>>If the tensioers have jumped timing, it can bend valves- It might have jumped but not yet jumped enough to crash.
Is engine failure a common problem?
>> Two known engine weak points, the tensioners and Nikasil
What exactly should I check/ look at to diagnose what the problem may be?
>> If you can run a compression or leakdown test, it would be valuable.
I have tools, what should I bring with me?
Oh... If I'm not mistaken, Ford actually owned Jaguar in 2000, So can parts be obtained cheaper now and what motor is in the XJ8L?
>> Heh, heh-you might think so, but the parts for the Jag are expensive and not too many are common to the Ford. The 4.0 liter overhead cam engiine is unique to Jaguar although the Lincoln 3.9 is SIMILIAR.
If there is anything else that I need to know, please keep filing in the blanks. While I wait for the respones, I will be trolling the search function myself but time is of the essense because I really want to look at this car in the daylight and hopefully drag it home tonight.
>> The Nikasil engine is not easily rebuilt. Nikasil liners mean the only practical way to rebore is to install steel sleeves. Pistons, rings, bearings, cranks and so on rarely fail, but are VERY expensive and not readily available. My opinion- If the engine is shot the car has 125,000 miles or so, the max price I would spend is $1,500 or so. A used engine is about $2,000 to $2,400 ans about 20 or 25 hours for the average shadetree to put in the first time.
Old Jul 10, 2011 | 09:14 PM
yeldogt's Avatar
Concidering the price you can purchase a perfect XJ8 today -- I would really crunch the numbers before I bought an unknown one with a bad engine.
Then I would check them again.
mikiep
Dec 20, 2019 07:37 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
