Quick Valve cover question
Old May 18, 2019 | 06:04 PM
OUScooby's Avatar
Default Quick Valve cover question
So I'm putting my valve covers back on my car and I seem to be missing the two bolts that go in the center of the vavle cover in the middle of where the coil packs sit (I've circled it in green in the pics below)
I got the photos below from some ones timing chain replacement walk through and I can't quite tell but it looks like there bolts go in a sleeve like all the bolts around the edge of the valve cover.
My question is this, do I need to order these sleeves or is this just a simple bolt and a flat washer.
Thanks.
Old May 18, 2019 | 07:15 PM
Dutchy's Avatar
He mate just took this photo of mine for you
Bolt washer spacer and washer
Old May 18, 2019 | 08:30 PM
OUScooby's Avatar
Ok so it is the same bolts and as the rest of the valve cover. I guess I'll borrow a few from around the edge of the valve cover and use those there so I'm not held up waiting for them to arrive. Thanks.
David Bedoya
Jan 15, 2017 04:12 PM
TexMurphy
Mar 22, 2016 08:10 PM
TopHatChef
Apr 28, 2015 01:29 PM
jamdmyers
Jun 17, 2014 12:50 PM
bootleg
Jul 3, 2008 02:45 PM
