Radiator drain? ?
Old Oct 6, 2016 | 10:51 PM
skinnypuppy_22's Avatar
Default Radiator drain? ?
So I have to replace the bypass hose. ..it's leaking a little and is very swollen. Needless to say I need to drain the radiator. .looking at pictures it appears it's on the side facing the engine on the driver side. .am I correct? ?
Old Oct 6, 2016 | 11:26 PM
nilanium's Avatar
correct, it will be a plastic plug in that bottom corner, US driver's side, facing engine. it might have a tab/wing thing sticking out, you don't want to use that to unthread it as it will probably break off
porschefixer
XJ40 ( XJ81 )
Sep 17, 2016 10:29 PM
Bavery767
Sep 16, 2016 07:54 PM
davetibbs
Sep 12, 2016 03:20 PM
StellaLunaGardens
Sep 9, 2016 01:50 PM
rocketlift
Sep 7, 2016 04:52 PM
