Radiator Drain?
Old Nov 9, 2009 | 01:41 PM
ronmexico's Avatar
Default Radiator Drain?
Sorry for the dumb question but my JTIS manual wasn't much help.
I have a 99 XJ8. Where is the radiator drain? Is there a drain on the radiator itself?
JTIS refers to a coolant drain on the engine block where a heater plug would go (if you have a block heater) but I can't seem to find it on the engine block (JTIS says it is on the left rear side). The access is pretty limited, even tried putting the car up on ramps.
Is this one of the jaguar deals where I have to take the car apart to perform a simple task? :-)
Old Nov 10, 2009 | 01:53 AM
Dan R's Avatar
There is a drain plug on the lower LH side of my 2008 XJ8. Some radiators may also have a plug on the lower RH side too.
Old Nov 10, 2009 | 02:13 AM
SuperSport's Avatar
Yep, on my left hand drive 99 XJR, it's bottom of radiator facing the rear of the car. A little like a Wing-Nut. Finger Tight.
hoodun
Feb 20, 2023 05:52 AM
Mac Allan
Jul 20, 2020 05:46 PM
wynlaidig
Sep 2, 2016 08:08 AM
Seth
Nov 1, 2015 12:17 PM
andyXJR
Sep 29, 2015 04:29 PM
