Radio Swap/Measurements
Old Apr 17, 2011 | 04:52 PM
jnunez's Avatar
Default Radio Swap/Measurements
Hello,
Does anybody happen to know what the dimensions of the radio inside of an 01 xj8? Like whats the height, depth and width? Is it even possible to change out the radio for a double din, like a touchscreen set-up? all help is appreciated.
Old Apr 21, 2011 | 11:53 AM
TheJagster's Avatar
Would be interested how you get on if you decide to go that route. Something I have considered.
Old Apr 21, 2011 | 03:00 PM
QuadManiac's Avatar
Standard double DN will not fit, single DIN will. There's room for a single at the bottom half, but only a couple of inches behind the plate in the upper half.
Old Apr 21, 2011 | 04:50 PM
Sean B's Avatar
Depending on which double din you choose, the shallower the better it will fit, but with modification. It depends on how much you want to do the conversion. To get the space you'd have to move the airbag module for clearance.
oldjaglover
Dec 25, 2024 04:33 PM
Paora
Feb 4, 2021 12:36 AM
philwarner
Jan 31, 2016 09:36 AM
ziondio
Sep 28, 2015 11:24 AM
