Re-affixing the rain-sensor to the windshield
Old Jun 10, 2012 | 10:28 PM
vdpnyc's Avatar
Question Re-affixing the rain-sensor to the windshield
What transparent goop/gummy-adhesive can I safely use to re-affix the rain-sensor to the windshield?
My rainsensor goop was no-longer really transparent from age (and thus not sensing rain accurately) and so about a year ago I removed the sensor and replaced the original goop with 3M clear-stickies that someone here recommended, but unfortunately they have already failed and are only holding the outer perimeter to the window, leaving slight air-space in front of the center sensor-area making it work totally erratically.
Thank you
Old Jun 10, 2012 | 11:56 PM
DavidB's Avatar
The gel pad part number is LJD3850AA, I believe it was about $7 at my local dealer.
Old Jun 11, 2012 | 12:27 PM
pdog2000's Avatar
order the pad like davidb mentioned...but be sure to get 2...you will probably screw it up the first time you do it :-) i screwed it up the first 2 times and had to order a third :-0
Old Jun 11, 2012 | 11:46 PM
vdpnyc's Avatar
Thank you!!!
Old Mar 28, 2013 | 09:02 AM
robertjag's Avatar
Default Automatic Rain Sensor Fix
My windscreen rain sensor was basically loose in the housing as it had come away from the double stick "gel" pad. It still worked pretty good.
I ordered a new gel pad and properly connected the sensor back to the windscreen.
Now the automatic feature does not work at all.
Any ideas?
Also, is there also a place the detects moisture and helps the windscreen wiper swipe?
Thanks.
philwarner
Jan 31, 2016 09:36 AM
King Charles
Oct 16, 2015 01:25 AM
