Rear Air Vent Modification
Old Oct 15, 2011 | 08:09 PM
perezal's Avatar
Talking Rear Air Vent Modification
Hello; has anyone ever performed or heard of a modification to the rear air vents to increase air flow on an X308?. I believe the X305 have a rear air-blower system “motor” which increases the air flow to the rear passanger area. I am interested in modifying my rear system to increase the air flow.
Al Perez
Irvine, Ca
2001 VDP SC
1984 SIII
1974 SII
Old Oct 15, 2011 | 08:15 PM
Ipc838's Avatar
Mine can only be described as "asthmatic" as well. terrible air flow, might as well not be there. No idea how to increase flow though. Watching this thread.
Old Oct 15, 2011 | 10:04 PM
pdog2000's Avatar
i think you'd have to add another blower somewhere...although if the foam sealing around the back vents come loose, than some air is going into the center arm rest console...that is what happened on mine, which is ok as it cools my T605 brains
Old Oct 16, 2011 | 05:51 AM
Sean B's Avatar
To improve the factory install, it's a case of removing the front seats, centre console and carpet. Then duck taping the joints in the ducting. Also removing the foam inserts in the under seat vents. I did this on my rebuild as a matter of course, and got it working a bit better than original. It's more noticeable with the air-con blowing. Weak to begin with, and not much better with tweaks, but better.
RaceDiagnostics
Sep 7, 2015 07:28 AM
Tar
Sep 6, 2015 11:24 AM
Corycarlo
Sep 5, 2015 11:41 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
