rear brake piston
Old Oct 11, 2008 | 12:44 PM
kats98's Avatar
Default rear brake piston
I'M DOING A BRAKE JOB 98 XJ8.COULD ANYONETELL ME HOW TO GET CALIPER PISTONS BACK IN. I'VE BEEN TURNING BUT NOT MOVING. PLEASE HELP
Old Oct 11, 2008 | 01:00 PM
christo's Avatar
Default RE: rear brake piston
Have you tried turning it the other way?
Old Oct 11, 2008 | 04:26 PM
JagXV6's Avatar
You need to turn turn and push to get the piston back in. There are
special tools to do it. Also on one side of the car you need to turn
it clockwise and push and on the other side of the car you need to
turn counter clockwise and push. I am not sure which side is which.
Also don't discount the fact that you may have a stuck caliper and
you will need to replace it but try the turn and push method first.
Old Oct 11, 2008 | 05:55 PM
Dennis's Avatar
ud
On the X Type at least, (I imagine they are all the same)the Right side while looking forward..turns in Clockwise (CW) and the Left side turns in Counterclockwise (CCW)..Also open the bleed nipple while you do this, as that will let the caliper piston retract easier....Don't forget to bleed the brakes when your done..
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
