rear console
Old Feb 26, 2014 | 11:34 AM
obriendob's Avatar
Default rear console
Hi
I picked up a rear console for from XJ8, from Ebay. The part came off a 98 VDP.
If the rear floor pre-drilled for this console?
If not, would I do damage starting hole for self tapping sheet metal screw?
Old Feb 26, 2014 | 12:23 PM
luc's Avatar
luc
Originally Posted by obriendob
Hi
I will not call it pre-drilled, what you have is 2 brackets welded to the floor pan and you use 2 screws and U shaped spring clip going through those brackets so there is no drilling of the floor pan
JAK60805E spring clips
AB610081J screws
WJ105001J washers
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
jagent
Sep 12, 2015 01:40 AM
arnoldmilk
Sep 3, 2015 07:42 PM
XFR_Gold
Sep 2, 2015 12:24 PM
