Rear shock bolt size?
Hello all. The right rear shock bolt is seized to the shock bushing and I'm planning to cut it free. Does anyone know the size of the bolt so I can buy a replacement before hand?
David
David
It's not a standard threaded all the way bolt. It is specific to that suspension design. The part number is JZB100036 and looks to be less than $15. They do seize in there so make sure you use some anti-seize when you reassemble it.
KarimPA
Sep 12, 2015 08:15 AM
Tar
Sep 6, 2015 11:24 AM
