Rear Sunblind?
Old Jun 13, 2015 | 08:51 AM
smtguy's Avatar
Default Rear Sunblind?
Is it possible to retrofit a rear retractable sunblind to my XJR? Has anyone done it? If so, where do you source the parts? Any information would be appreciated.
Thanks.
Old Jun 13, 2015 | 11:00 AM
Jhartz's Avatar
Check with Barrett. My first X308 was a Canadian model: it had a factory sunblind -- which leads me to believe it is available as a replacement and probably has the holes already tapped for the screws.
I also remember some VDP models came with a factory sunblind: might check a couple of the junk yards that specialize in Jaguars in your area.
Old Jun 13, 2015 | 03:09 PM
JaguarLover101's Avatar
I fitted the sunblinds on my 01 XJ8, got a parcel shelf with them fitted at the local scrappy, the catches at the top are already there, just need to remove rear seats which was a bit of a pain, best of luck!
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
AtholC
Sep 9, 2015 09:07 PM
timm525
Sep 8, 2015 07:57 PM
