Removing the Grille?
Old May 16, 2015 | 03:16 AM
Pilotman11's Avatar
Default Removing the Grille?
Hello everyone! Tonight I had an idea to replace my stock XJ8 grille with a VDP grille. The question is; how could this be done? Is there a tutorial video anywhere showing how it can be done even? Thanks everyone; and have a good weekend!
Old May 17, 2015 | 12:10 AM
Pilotman11's Avatar
Or would it be simpler to let my mechanic do it? ( Sorry for the double post )
Old May 17, 2015 | 05:22 AM
andrew lowe's Avatar
If you look at the top of each gill insert, (about a fingers length in from the outside) there are two screws.
remove these, pull the insert forwards and up to remove.
There are four torx screws, one in each corner, remove those to remove the grill shell.
And as they say, refitting is the reversal of removal.
Should take all of 10 mins to do (unless you stop for a cup of tea!)
Quantico
Oct 13, 2015 10:34 PM
bigdhenderson
Sep 29, 2015 05:29 AM
danke
Sep 24, 2015 02:41 PM
doctordeuce
Sep 12, 2015 08:30 AM
1964Daimler
Sep 9, 2015 11:28 AM
