Replaced Front Lower Control Arm Bushings
Old May 10, 2008 | 10:18 PM
Tomlite's Avatar
Default Replaced Front Lower Control Arm Bushings
Big Improvement
Since I now have 27000 miles and the bushings were replaced at 9000 miles, now the inside edge of the front tires was wearing. After tons of research, I decided to replace the Front Lower Front Bushings. I ordered the bushings for the FrontLower Rear which are dimensionally the same, but firmer.
In short, without research time.
Placed jack stands under front frame. Supportedlower arm with floor jack. Marked position of front alignment bolt, removed bole, removed floor jack. Removed front control arm. Turned a steel bushing the OD of the part to be removed. Hammered out old bushing. Inserted new bushing with10 Ton arbor press. Replaced control arm. Installed front alignment bolt while lifting assembly with floor jack. Set alignment bolt to settings marked.
Really improved handeling.
Old May 11, 2008 | 08:56 AM
FactoryJaguarTech's Avatar
Default RE: Replaced Front Lower Control Arm Bushings
So you used the front rear in place of the front front?
Old May 11, 2008 | 12:30 PM
Tomlite's Avatar
Yes, the front lower rears are much stiffer. They work really well so far
Old May 11, 2008 | 02:30 PM
jag_genius's Avatar
thats what the front bushings updated to.. the rear ones..
Old May 11, 2008 | 10:22 PM
Tomlite's Avatar
Default The Pristine Parts Guy at Jaguar will Argue
The Pristine Parts Guy at Jaguar will Argue that point. But, that is where I got the Idea to use the Rear Bushings. So far, I am very satisfied with the improvement in Handling.
Old May 12, 2008 | 05:18 PM
Rock Meathammer's Avatar
Default RE: The Pristine Parts Guy at Jaguar will Argue
That's good info to know, I'll remember that.
philwarner
Dec 6, 2021 07:13 AM
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Doug Dooren
Aug 30, 2015 08:51 AM
perfectphoto
Aug 29, 2015 10:11 PM
