Replacing innner tie rod end.
Old Aug 14, 2016 | 02:04 PM
OUScooby's Avatar
Default Replacing innner tie rod end.
Went to get an alignment yesterday after the put up the car they told me the couldn't align it because the inner and outer tie rod ends were worn on the passenger side. The out tie rod end is an easy fix, and the part is easily available but I can't seem to find the inner.
Does anyone know if its possible to get just the inner tie rod, and if so where? Or am i stuck removing and either replacing or rebuilding the whole steering rack?
Old Aug 15, 2016 | 06:27 AM
Computer Budda's Avatar
Inner tie rod ends seem to be available at rockauto but I don't know the year of your jag I can't tell if yours is.
Old Aug 15, 2016 | 09:53 AM
CharlzO's Avatar
Was just discussed a week ago as well:
https://www.jaguarforums.com/forum/x...d-them-166934/
If it helps.
Old Aug 15, 2016 | 10:55 PM
OUScooby's Avatar
Car is a 2000 XJR
If it helps.
Thanks saw the link on jag bit, more than I'd like to spend, I'll try rock auto
Old Aug 15, 2016 | 11:00 PM
OUScooby's Avatar
Actually I'm not seeing it on rock auto, i see the outer but not the inner
Old Aug 16, 2016 | 09:53 AM
Mark SF's Avatar
Inner tie rods are all over Ebay, like a rash
Old Aug 17, 2016 | 06:13 PM
vdpnyc's Avatar
Inner tie rods are sold on rock auto as part of the steering assembly and are refurbished, you cannot just buy the inner tie rods
Greggbhill
Jul 15, 2019 04:09 PM
BobRoy
49
Sep 18, 2016 10:48 AM
jfleming
XJ40 ( XJ81 )
Apr 10, 2016 12:42 AM
IronCobra
May 21, 2013 01:44 PM
Nov 29, 2005 10:59 PM
