Replacing/respray interior door pillar plastic
Old Jan 24, 2023 | 01:53 PM
asjdhsajhdfj's Avatar
Default Replacing/respray interior door pillar plastic
Hi all,
I’ve got a hypothetical project to do.
I’ve to respray the beige pillars on the interior to black. If not respray, then I can use a direct black replacement.
Also, the surrounding of the gearstick, head unit (whole leather piece), can that be removed with ease?
Is there a guide for the above?
Old Jan 24, 2023 | 10:28 PM
collector's Avatar
Originally Posted by asjdhsajhdfj
Hi all,
If you live in the US, there is a company that will make your interior dye to match whatever color, if it’s vinyl you’ll use Color coat and if it’s leather it’s an elastomeric water based dye. If you go that route, you’ll never be able to tell it was ever sprayed and it will not change the texture or scratch or peel. Also, they’ll match your sheen as well. All for the parts your talking about are vinyl, unless it’s a VDP then those pieces are also vinyl as well, except for the arm rests. The leather dye can be rubbed on or thinned to spray in a Preval. They both dry instantly. Vinyl Pros in Marietta GA. do exact matches.
Old Jan 25, 2023 | 03:43 AM
markdpeter's Avatar
Hi all,
It's very simple, it took me about ten minutes at the weekend. You can find full instructions in the manual but I've attached the sections I referred to.
File Type: pdf
moroza
Jul 26, 2020 07:35 AM
650
Australia - Western
Jul 25, 2015 12:50 AM
liquidreality
Aug 18, 2014 10:12 PM
bigmatt357
Aug 7, 2014 11:07 PM
philhef
Oct 24, 2013 04:29 PM
