Restricted performance - code p0353
Old Jun 11, 2018 | 11:22 AM
JagJoe80's Avatar
Default Restricted performance - code p0353
I had a problem with my X308 previously and will be replacing the Throttle Body next week but whilst driving it yesterday the above came up with the orange light. I did the usual switch on and off and disconnected the battery. But today the same fault cam up.
I've read a lot of posts on this forum but cant seem to find the fault.
I replaced the battery, so I know it not that. I believe P0353 is ignition coil A3. I will check the connections and wires to make sure they are not bare and touching the metal.
My main concern is I am in Cardiff and need to get to London tonight with restricted performance, is it safe to drive it 200 miles.
Do not that the car has LPG system
I would appreciate any advice you can give me.
Cheers as always.
Old Jun 11, 2018 | 02:03 PM
Sean B's Avatar
switch the offending coil round with its neighbour and confirm if fault code follows it/faulty - any chance you can get a spare?
Running with a faulty coil can cause issues like melting it. But you need to know if it's the coil.
Old Jun 11, 2018 | 03:08 PM
RJ237's Avatar
You can also damage the catalyst.
Old Jun 11, 2018 | 04:29 PM
JagJoe80's Avatar
Thank you very much with your very helpful advice. Will call AA and get towed back to London, then check coil and plugs and change of need be.
Thanks again you've both been very helpful.
Old Jun 14, 2018 | 10:55 AM
JagJoe80's Avatar
I did as suggested and changed No3 coil for No 4 and came up with 0354. So replaced coil and all seems ok so far.
As I said I still need to replace the Throttle body which I will do soon.
Thanks again for all your advice much appreciated.
Cheers.
Old Jan 20, 2023 | 01:07 PM
Z06Norway's Avatar
Default I know its almost 5 years ago, but I have same fault
Cheers.
Old Jan 20, 2023 | 03:20 PM
RandyS's Avatar
5 years with the same fault is a long time..
blackhonor9
Apr 4, 2015 05:03 AM
ugotmale
Jan 28, 2015 02:39 AM
filred
May 11, 2010 04:45 PM
dijmand
May 11, 2010 12:31 AM
lazboytt
Jun 3, 2008 05:02 AM
