Right Front Passenger Door Lock
Old Feb 14, 2010 | 03:19 PM
jagmarine's Avatar
Default Right Front Passenger Door Lock
Does the right front passenger door lock have an individual fuse/relay that is associated with it. I've tried lubricating the lock and it won't work. I can hear the mechanism working inside and when I push it down mechanically I can here it attempt to lock the rest of the doors. I hoping to avoid having to replace the entire door lock actuator (GNA1080DG). Jagbits sells them for about 400 new and 250 used.
Old Feb 15, 2010 | 07:41 AM
Stu 1986's Avatar
No No No! Don't buy it!
Seriously I had the same problem with a lock on my Xj, and got a used lock mech on ebay for £20. I even posted directions on how to do the job here: https://www.jaguarforums.com/forum/s...ad.php?t=32658
Its dead easy to do, and doesn't take very long. I wouldn't pay that much for such a simple part. I'm in Britain so used British Ebay, but even if you bought from them and had it shipped to the U.S. it wouldn't even come close to that price!
Seriously I wouldn't pay that silly amount. S.
Old Feb 15, 2010 | 08:01 AM
test point's Avatar
From the XK8 fuse chart there are 3 fuses associated with the passenger door. I suspect yours is similar but no guarantees. Since fuse charts are sorely lacking in owner documentation, Jaguar obviously thinks that fuses are beyond the technical level that owners need to be concerned with.
On the XK8/R the passenger (US) fascia panel has:
#2 labeled as Door Locking Actuators,
#4 as Door Switch Packs, and
#15 as Passenger Door Control Module.
If you would like the charts send me a PM with your external email address.
Old Feb 16, 2010 | 09:12 AM
johnleavitt's Avatar
I had the same issue with my 99 xjr...ended up replacing the lock with an ebay used lock for $100. Works great...what a pain in the neck is was before...worth every penny.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
Dz1rfj
Jul 17, 2018 10:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
bdboyle
Sep 4, 2015 06:16 AM
