Searching for Coolant leak!
Old Jun 15, 2024 | 06:43 AM
Ouro's Avatar
Default Searching for Coolant leak!
I'm not entirely sure what hose this is underneath the snout and thermostat housing is. Im trying to tackle a coolant leak, and I notice a bit of water/coolant sitting in this area.
I should preface this that my engine overheated.
Old Jun 15, 2024 | 07:22 AM
Addicted2boost's Avatar
That’s one of the 2 heater hoses underneath the blower that has to come off to replace.
NCC3945AC
Did both cooling fans turn on? Make sure both of them turn on when the A/C is on as a quick test. If so, maybe the thermostat stuck closed?
Old Jun 15, 2024 | 03:54 PM
RandyS's Avatar
A2B makes a good point, and make sure your water pump is not leaking.
If so that could be your main culprit.
chemosabe
22
Jun 14, 2022 01:21 PM
Anglicomarine0326
May 31, 2022 11:06 AM
atlcontracting14
May 10, 2020 03:13 PM
xtypejag502
Jun 16, 2016 01:09 AM
sempire
Nov 18, 2010 09:20 AM
