side marker lamps will not go off
Old Oct 30, 2017 | 02:53 AM
MeNobodyy's Avatar
Smile
Hey i had the same problem yesterday with my hazard lights and this is what i did. I waited for my battery to drain, then i jump started it with another car's battery thats one option. If all 4 side markes won't shut off then try this. Or you can do this. Take some electrical contact cleaner and spray the hazard switch while turning it on and off. Then reconnect the battery cable. The secon option is only if youre having problems with the hazard lights. You can also disconnect the batery cables wait some time and then put them on the battery again maybe that can fix the problem. Best Regards Angel
danke
Mar 3, 2016 10:57 AM
afterburner1
Dec 16, 2015 12:12 AM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
