Silicone between throttle body and intake elbow?
Old Dec 10, 2011 | 06:26 PM
JaguarXJR02's Avatar
Default Silicone between throttle body and intake elbow?
In the process of reassembling the air intake systems after installing a rebuilt supercharger, is it appropriate to add some type of silicone sealant between the bottom of the throttle body and then intake elbow? it appears that there is some residue of previous sealant, but I want to be sure.
thanks in advance
Old Dec 10, 2011 | 07:13 PM
Sean B's Avatar
no sealant whatsoever. Uses a steel gasket and correct torque to bolts. Clean surfaces really help the seal. Being supercharged it's important. Silicone is evidence of a botch job.
Old Dec 10, 2011 | 11:00 PM
jchavez76's Avatar
Silicone is nice when you don't have to take it apart on a semiregular basis. On a throttle body or intake tubes, it's a mistake. Go with the O.E. type gaskets or seals on that application.
Old Dec 11, 2011 | 10:07 AM
very good, should have her back on the road within a few weeks
Old Dec 12, 2011 | 07:41 PM
D. Fite's Avatar
Just a thought concerning silicone sealant. I have worked with Industrial (RTV) silicone for many years in my job. It is a very good sealer but use it sparingly. Too much and it can ooze out making a mess but worse ooze in causing all kinds of internal problems. Never use silicone with a rubber or neoprene gasket. I have had the opportunity to experiment with all kinds of different sealing compounds. Had some good results and a few not so good.
Hope this helps.
Dave
clubairth1
30
Sep 3, 2025 04:38 PM
xjrjag
Oct 24, 2024 03:09 PM
mhamilton
67
Apr 1, 2021 03:20 PM
Gus
Oct 15, 2019 12:29 PM
