Squeaky Center Console Lid
Old May 4, 2012 | 04:39 PM
OldMike's Avatar
Default Squeaky Center Console Lid
I saw a thread the other day about a squeaky center console lid, but I can't find it now. I don't think it was specific to the X308, however.
Mine squeaks when I lean against it. It squeaks when I press on the top with the lid open or closed.
So, I took the lid off to see if I could tighten anything up but I was not able to remove the leather padded part from the interior plastic under-lid. I decided to leave well-enough alone and put it back together before I broke anything! I can live with the squeak, but would rather not have to listen to it (I know, turn the radio up! LOL).
Any suggestions?
Old May 7, 2012 | 05:36 PM
rocklandjag's Avatar
Mine was also squeaking whenever I leaned against it. I disassembled everything. including the top and the entire cup holder mechanism. Then I glued every part back together during re-assembly using silicone caulk. Took a little while but nothing squeaks anymore, not even the if you push on the front cupholder assembly.
You could try just the top 1st, that is the easy part
Swagguar
Aug 11, 2019 04:50 PM
adam699
Oct 13, 2015 05:53 PM
goingjag
Sep 30, 2015 09:27 PM
42Ajd
Sep 26, 2015 07:04 PM
