Stability Control Fail Message, PLEASE HELP!
Old Dec 31, 2010 | 11:16 AM
Elizabeth's Avatar
Default Stability Control Fail Message, PLEASE HELP!
If someone can please help me! My 1999 xj8 is not feeling well...the stability control fail message keep coming on and then she acts like she's going to stall, and goes slow, I pull over and turn her off for 5 min. start up and she's ok, until she does it again. From what I keep reading it could be a corroded connector, module (what is this)...and possable brake situation...Can I fix this myself? Does it have anything to do with the brake fluid?
How expensive is this to fix? I have limited funds right now...HELP!
Thanks,
Elizabeth!
Old Dec 31, 2010 | 11:29 AM
steve11's Avatar
ud
Hey Elizabeth,
Failed Stability Control message is not usually an independent failure, instead is it usually associated with another failure often related to engine management. Along with this message, you must be getting a CEL too. This is a dash light either red or yellow that might or might not extinguish when the DSC message goes away. It is also likely the primary cause of the engine stumbling and wanting to stall. I can give you at least a dozen guesses where to start looking, or the real way to diagnose the problem is to get the codes read that are stored. It will pinpoint an issue and give us a much more accurate attempt as assisting you.
You can get the codes read at any Autozone, or other parts stores possibly. Other repair shops might be kind and read them for you too, or charge you to read them. Come back with the codes and we'll help.
Old Dec 31, 2010 | 11:38 AM
Elizabeth's Avatar
Default Thank you
Thank you very much...I will see if anyone is opened today and get that done...and I will come back and tell you what it says...I REALLY APPRECIATE your help!!!
E
Old Dec 31, 2010 | 11:40 AM
Gus's Avatar
Gus
Without the codes it is hard to say what the cause is. However, if it is ABS/Traction control related this is a great post with photos for you to read that addresses that problem https://www.jaguarforums.com/forum/s...ad.php?t=37907 I hope this helps.
Old Jan 3, 2011 | 04:52 PM
Elizabeth's Avatar
Default OK I have the code
Hi Guys...Ok here is what happened over the weekend...the upper radiator hose had a split...fixed this morning...but when the codes where read after it said manufacture control Auxiliary input and output...the only two codes that it read that seemed to be a problem....all the check engine lights, came on...any suggestions on what is going on now...?? Thanks for your help!
Old Jan 3, 2011 | 05:31 PM
Gus's Avatar
Gus
I am sure the upper hose put a damper on things. As for the stability control fail do you have the code numbers(P0xxxx) that they found if any?
abonano
25
Sep 25, 2015 10:43 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
Havigdort
Sep 13, 2015 04:42 AM
jaguarbill
Sep 5, 2015 11:43 AM
XFR_Gold
Sep 2, 2015 12:24 PM
