Start Help after the winter break
Old Mar 4, 2015 | 12:36 AM
dixj300's Avatar
Question Start Help after the winter break
Dear Jag drivers,
I have a problem and would like some help from people who know the XJ308 machines. During the winter I forgot to go and start the engine on a regular basis and now all it does it turn and turn and turn over. Is this caused by a battery which isn't strong enough?
I have recharged the battery but it only shows 11.7v across the poles. What do you all reckon? Is there a ritual to go through after sitting around for 4 or 5 months?
Paul
Old Mar 4, 2015 | 01:17 AM
CharlzO's Avatar
Could be just the weak battery, could be a fuel problem too. First step would be try to charge / jump it, and see if that helps. Maybe a a bit of gas treatment in the tank as well (water remover/DryGas, whatever it might be called in your region).
Old Mar 4, 2015 | 02:45 AM
Originally Posted by dixj300
........... During the winter I forgot to go and start the engine on a regular basis and now all it does it turn and turn and turn over. ..........
Paul,
In the HOW TO thread at the top of this tech forum you will find:
X308 Charging/Starting Troubleshooting Rev 2.2 (by avt007): http://www.mediafire.com/view/j4irvg...g_Rev._2.2.pdf
A comprehensive guide to troubleshooting non start issues on the X308.
Old Mar 7, 2015 | 08:44 PM
junioramy1's Avatar
just had the same exact problem my jag has been sitting for about 8 months while i was working on it time to time what worked for me was push gas petal to floor then crank it. If it tries to turn over kinda ease off pedal , what i had to do to mine was hold gas pedal at a steady rpm until car was warm enough to stay on by itself but might have to try this a few times
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Bowman
Sep 15, 2015 06:54 AM
Bones
Sep 8, 2015 08:34 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
