Stop lights & key fob not working
Old Jan 31, 2022 | 06:48 PM
  #61
Parker 7's Avatar
The key position chart is on to of page 98
This is where things get mixed up as some key positions make more than one pin position
See top chart page 98
X300 00/E COVER (jagrepair.com)
Old Jan 31, 2022 | 07:20 PM
  #62
Parker 7's Avatar
On key insertion before rotating is position 0
So 1 brings your radio on
2 powers up the Engine ECU
3 is the starter
After 3 it springs back to 2
Old Feb 1, 2022 | 09:43 AM
  #63
LockNumber25's Avatar
Originally Posted by Parker 7
Definitive proof would be BT4 pin 18 resistance to car frame ground with the brake pedal depressed and not depressed
This should go to zero resistance to trigger brake light illumination , high resistance for brake light off
This would be car side forward half of tghe BT4 connector
  1. BT4-18 > frame ground - 1.7 Ohms with brake depressed, no circuit when not depressed
  2. BT4-18 > BT2-1 > pin inside SLCM (see pic) to frame ground - 1.7 Ohms
Looks like the SLCM is getting a solid ground trigger? Maybe re-seating BT4 has helped? I did go a step further to see if issue was resolved but unfortunately not (no V on BT1-9 U or BT1-3 OG)
Old Feb 1, 2022 | 10:14 AM
  #64
Parker 7's Avatar
Yes , looks to be a issue inside the SLCM , trying to cover bases before that
SLCM properly grounded on pin BT1 - 13 and 14 ?
So this would be the other SLCM connector from the BT2
Both ground wires Black / Pink color , this is a odd ground stud location that can get disturbed on rear seat removal so you can provide a ground path on a different existing ground stud location like on the side of the battery tray
Old Feb 1, 2022 | 11:41 AM
  #65
Yes, 0.2 Ohms from solder inside SLCM to ground stud.
Old Feb 1, 2022 | 12:45 PM
  #66
Parker 7's Avatar
Time to source a SLCM
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Feb 1, 2022 | 02:08 PM
  #67
Had a feeling. I've sourced some solid state relays as these seem to be a common failure on the SLMC. Should be here in a couple of days.
Thanks so much for sticking with me on this. I really appreciate it. I've learnt a ton. Will update once I've installed the replacements.
Old Feb 1, 2022 | 02:40 PM
  #68
Parker 7's Avatar
Take good pics of your repair that others behind you can follow
Would you with your knowledge be able to hard rest the SLCM outside of a hard reset of the whole car
The hardware in the SLCM may be OK and locked in a frozen state
A whole car hard reset in the UK locks out your original Jaguar stereo head as a security design
Old Feb 1, 2022 | 03:07 PM
  #69
Will certainly take pics and post. I have the radio removed at the moment, so safe to hard reset or no?
Old Feb 1, 2022 | 04:02 PM
  #70
Parker 7's Avatar
US models were safe from this up to year X ( X300 models )
All X308s were not safe from this from my understanding
In a hard reset the positive battery terminal cable is connected to ground draining the capacitors and latching gates in the devices
This brings the logic steps ( or commands to items like solid state relays ) in the device to zero state or to be able to trigger or change a item to a desired state
Old Feb 3, 2022 | 09:51 AM
  #71
SUCCESS!!!
@Parker 7 - Sir, thank you so very much. I'm so happy we got a result. Thank you for sticking with me on this.
As others have experienced; the issue was the solid state relays inside the SLCM, both were blown.
Replacement part is: BTS409L1 SMD
I ordered from this vendor in the UK
https://www.ebay.co.uk/itm/191920715821
Here is the replacement part on the right (please don't hate on my soldering skills!!)
Old Feb 3, 2022 | 10:13 AM
  #72
Parker 7's Avatar
So it was a hardware component / relay
Part # and source for others?
I see it now BTS409L1 SMD
https://www.infineon.com/dgdl/Infine...5aa9b0a1b7361a
Liquid solder ? I get mine in a small syringe tube from a local electronics store in town
Old Feb 3, 2022 | 10:23 AM
  #73
Yep, mentioned replacement part # in my last post and the eBay vendor I bought them from. Sorry, not familiar with liquid solder.
Old Feb 3, 2022 | 10:37 AM
  #74
Parker 7's Avatar
Trying to find picture and it wicks up easily into your work with little carry over across pins
Low melting point to protect the device
Old Feb 3, 2022 | 11:57 AM
  #75
Interesting. I shall grab some for the inevitable next project.
karenh
Sep 3, 2020 03:59 PM
Cobbler
Feb 24, 2017 04:34 PM
daddylogan
Nov 27, 2016 07:18 PM
quaker13
Mar 4, 2012 08:08 PM
smileboot
Apr 27, 2007 11:05 PM
