Strange issue After my 97 xj6 starts
Old Mar 19, 2011 | 07:53 PM
mvagts's Avatar
Thumbs down Strange issue After my 97 xj6 starts
Hi-
I hope someone can help regarding my issue before i take it in to be looked at. Every time that i start my vehicle; it starts then the engine dies out. When i start it and rev the engine it becomes fine and runs like normal. I found some possible causes but wanted to get some professionals opinions: possible PCV valve sensor, throttle body issues? I am not sure, it was idling faster than normal when i start and get it to keep running.
Anything would help,
Last edited by mvagts; Mar 19, 2011 at 08:04 PM. Reason: The check engine codes were: P1509 and P 0507; if anyone knows anything about those, that may help as well.
Old Mar 19, 2011 | 09:23 PM
Brutal's Avatar
to start, take the throttle body off, clean the throttle and especially the IACS, (idle air control solenoid) passage. if the valve is slow it wont control idle properly and with a dirty throttle bore it really depends on the iacs for idle control. try that first.
toronadomike
Jan 22, 2026 10:13 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
TXJagR
Mar 12, 2016 11:12 AM
tberg
Sep 7, 2015 07:32 AM
1964Daimler
Sep 2, 2015 11:41 PM
