Subframe movement
Old Jun 1, 2014 | 08:17 PM
Badbenz94's Avatar
Default Subframe movement
I have read many posts on the subframe bushings being replaced and wanted any insight.
As I replaced by lower bushings on the shocks I jacked up the car at the jack point right behind the front wheel. Before I lowered it on the jack stand under the subframe right behind the front a-arm mount, I examined the v mounts and surrounding area. Everything looked fine.
I did notice that when I lowered the car onto the jack stand the subframe moved about a 1/2"? Is this acceptable or should there be absolutely no movement? I noticed the v mount compress some. Btw I only jacked up one side at a time if that makes any difference.
Thank you,
Chris
TreVoRTasmin
Feb 23, 2021 03:13 PM
afterburner1
Dec 16, 2015 12:12 AM
tomkilner
Oct 9, 2015 07:10 AM
andytork
Sep 24, 2015 06:35 PM
