Sunroof problem
Check this thread out, particularly post #18, I believe Eric's post shows what you may be needing to know. https://www.jaguarforums.com/forum/x...-problem-9341/
Tilting it up (if that works at all) will reveal if you have this problem.
After tilting, look from the outside of the car.
You will see the steel roof panel, and below that the inner panel.
Those panels should have a gap in between them, but that gap should be equal at both sides.
If the inner panel dropped at one side, that is where you got to start checking.
