Sunroof seal
Old Nov 23, 2016 | 09:51 AM
user 652867429824's Avatar
Banned
Default Sunroof seal
Replacing the seal on my sunroof as the old one is dried and worn. I noticed that the TSBs and the manual calls for the use of Jaguar crimping tool JD 200, which is discontinued (and bet was expensive). is there an alternative way to crimp the seal
Old Nov 23, 2016 | 10:50 AM
convincor's Avatar
I tried to buy one about 6 months ago. They were still listed @$150, but after I placed the order I was told not available.
My next thought would be to try dealer service. Maybe borrow it?
If not I may sacrifice a pair of channel locks and make something.
Old Nov 23, 2016 | 10:51 AM
convincor's Avatar
https://www.jaguarforums.com/forum/x...on-x300-76113/
Old Nov 24, 2016 | 03:08 AM
Banned
I tought of doing the same thing, after searching just seems nothing similar to use can be found. maybe one of use will come up with something
Old Nov 25, 2016 | 08:16 AM
Banned
Was sitting here searching for a tool to crimp the seal, and was just giving thought, is there a reason to crimp or could you ude some type of sealer instead
Old Nov 25, 2016 | 09:12 AM
Samilcar's Avatar
After my repaint, I partially crimped the most opened parts of the seal with pliers, and then pressed it back onto the panel by hand. It's worked so far (almost a year), but I never open my sunroof.
