Sunroof stuck open :(
Old Apr 29, 2015 | 03:21 PM
thecapn's Avatar
Default Sunroof stuck open :(
Hello all, I have a 2000 XJ8 that the sunroof recently stopped working after I opened it. (Tilted up not fully open) It then stopped working. I can't hear any motor noise and I checked the fuse and that's fine. Is there a way I can manually close it or another fix to try? It doesn't look like anythings broken just that the switch is not working.
Old Apr 29, 2015 | 04:08 PM
kp98xj8's Avatar
First thing to try is a hard reset. Loosen negative battery clamp, pull it off battery post, stretch it over to touch it and hold it against positive battery post for about 30-40 seconds. Essentially a reboot of your car's computer system. Restore cable back and tighten clamp.
Retry your sunroof and see what ya get.
If hard reset doesn't work, try here... page 99.
https://www.dropbox.com/s/a1glty7tiu...s%20manual.pdf
Old Apr 29, 2015 | 10:00 PM
motorcarman's Avatar
You can manually move the sliding roof with a large flat blade screw driver in the motor drive gear assy.
I also uploaded all the X300/X308 TSBs for the sliding roof fixes, faults and issues.
Look in the large file download area. (the roofs are the same)
bob gauff
Old Apr 29, 2015 | 11:30 PM
Auspuff's Avatar
What?
Maybe I'm reading this wrong. Sounds like a guide to shorting out the battery to me ...
Old Apr 30, 2015 | 01:02 AM
kp98xj8's Avatar
Originally Posted by Auspuff
What?
I've done it dozens of times and never suffered any such calamity. Do a forum search on "hard reset". You'll see...
Here's a thread..
https://www.jaguarforums.com/forum/x...unction-42885/
It's mentioned and suggested probably 10 times a day around here. I do it without even thinking anymore when the sunroof acts up or a window misbehaves. I've never encountered the "radio code" getting whacked when doing it either. All it's ever done for me is fix my problem.
Old Apr 30, 2015 | 07:07 AM
Auspuff's Avatar
Yes I was reading it wrong. Thanks for the topic link that was useful reading.
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
TexasCat
Sep 8, 2015 04:36 AM
King Charles
Sep 3, 2015 12:40 AM
