Tail light issues
Old Aug 22, 2014 | 03:53 PM
L3dz3pp3l1n's Avatar
Default Tail light issues
It all started with a "check tail light" warning while braking. Turns out I had a bulb out which is an easy fix right? I changed the bulbs on both tail lights and now I am not getting any dim red tail lights. When I apply the brakes, it illuminates the dim lights instead of the brighter brake lights. What have I done wrong? I feel like it's an easy fix but I can't get my head around it. It may also be worth mentioning that my lights (front and rear) only work on the automatic selection. Help on that would be appreciated too.
Old Aug 22, 2014 | 06:04 PM
andrew lowe's Avatar
Have you fitted the correct bulbs ? 5w / 21w twin filament single pole bulbs as opposed to a double pole single 5w bulb, they both have two contacts at the base and look very similar. Do the side/ parking lights at the front come on when you put your foot on the brake with the lights tuned off ?
Old Aug 22, 2014 | 07:26 PM
I'm pretty sure I got the right bulbs. The package says "Replaces 17916/P21/5W". And no, the front side parking lights do not come on when the lights are off and I press the brake.
Old Aug 23, 2014 | 03:06 AM
Heliwilly's Avatar
It is possible to put the bulbs in the wrong way. If you do, you only get the tail lights lighting when braking.
Take the bulbs out and check the locating pins on the bulb, one pin is higher than the other. Make sure the high pin on the bulb goes in the appropriate slot in the holder. Bill W
Old Aug 24, 2014 | 07:36 AM
So now I've flipped the bulbs around as Heliwilly suggested and now I am getting bright brake lights but still no running tail lights at night.
Old Aug 25, 2014 | 09:12 AM
Jhartz's Avatar
Either a broken wire or (far more likely) a single filament bulb. Pull it out and check it, again.
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
