Tech help please - aux coolant pump circuit
My 2001 XJR heater is suddenly very slow to warm up - it takes 20-30 minutes for the interior to come up to temp on a cold day. I suspected the auxiliary pump, however it powers up fine when supplied 12 volts. I discovered I have no power to the pump with the ignition on/engine running. Wondering if the car has to be up to temp before this circuit is powered, or should I be seeing 12 volts here on cold start? Fuse and relay are fine and no HVAC system codes. Any ideas appreciated.
When was the last time you flushed your system? The car is 20 yrs old, the heater core may have buildup in it? When did you last change your thermostat,...is the water pump original...if so the replacements have metal vanes because the OEM had crappy plastic ones and would break. So if water isn't flowing, neither is the heat.
I'd recommend downloading the x308 workshop manual, think you can get it from jagrepair.com, or the forums large files section (Jaguar Forums File Download Area, Folder Index - Jaguar Forums - Jaguar Enthusiasts Forum)
From the shop manual:
Located in the same area as the water valve, the water pump continually circulates coolant through the heater matrix
except when the conditions below apply:
-The engine coolant is below 16°C.
-The ignition is OFF.
-Under engine stall conditions, when ignition is ON.
-Control panel OFF
-Control panel OFF
Thanks for confirming the pump doesn't run on cold start - I'll warm the beast up and see if the pump circuit powers up. Water pump and thermostat were replaced along with timing chains and tensioners less than 5000 miles ago, and the heater core and evaporator are also new.
Catmobile
Nov 30, 2018 11:51 AM
Milowokie
Nov 15, 2018 09:09 AM
philwarner
Oct 5, 2016 11:24 AM
