Tech help please - wiper motor transplant
Old Jun 15, 2016 | 06:50 PM
Doug Dooren's Avatar
Default Tech help please - wiper motor transplant
The idiot transplanting the X308 into a Mark 2 is back. I had to replace the XJR wiper motor with a Series 3 XJ6 motor to be compatible with the cable drive of the Mark 2 wiper system - no room in the cowl area for the XJR wiper mechanism. As far as I can tell the motors are identical electrically, with wire leads for high speed, low speed, park switch and ground. Everything works as it should using the XJR wiper control, until I turn the wipers off - they continue to run for 10 to 12 cycles before shutting off, stopping randomly at different positions. Any thoughts regarding the cause/fix will be appreciated.
Here's a picture of the 2 wiring diagrams - no idea how to pull one from the XJR electronic manual so had to print and take a picture! The motor is in the lower right - hope it's legible.
Attached Thumbnails Tech help please - wiper motor transplant-xj6wiperschematic.jpg   Tech help please - wiper motor transplant-xjr-wiper-schematic.jpg
dinop
Jun 14, 2016 02:48 PM
Wilfred88
Apr 14, 2016 02:10 PM
vincent661983
Apr 2, 2016 12:59 PM
Ipc838
Apr 1, 2016 10:31 AM
Dale Konkol
Mar 30, 2016 08:28 AM
