Tech help please - X308 window motor
Old Jan 25, 2014 | 04:38 PM
Doug Dooren's Avatar
Default Tech help please - X308 window motor
I'm the idiot transplanting an '01 XJR into a Mark 2. In order to fit the power window mechanism into the door I need to power the motor to the down position. Looking at the wiring diagram it looks like the motor sees either power up or power down from the orange and blue wire, but when I ground the motor and power the leads nothing happens. Is there a simple way to operate the motor or do I need to hook up and power the control unit? I'll appreciate any thoughts. Here's a pic of the XJR mechanism replaced with the shorter Mark 2 one to fit the smaller rear door. Thanks.
Attached Thumbnails Tech help please - X308 window motor-mark-2-rear-window-motor.jpg
Old Jan 25, 2014 | 05:09 PM
avt007's Avatar
Try power on one wire, and ground the other one. If that doesn't work, reverse the leads.
The wiring diagrams don't show a ground, so they probably do it as above and reverse the polarity to drive it the other way.
Old Jan 26, 2014 | 06:31 AM
Rob, you were correct. Thanks again.
Forcedair1
Feb 19, 2020 01:51 PM
mikimogo
Sep 22, 2015 08:09 PM
mikimogo
Sep 14, 2015 08:34 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
1964Daimler
Sep 9, 2015 11:28 AM
