I really know that this topic has been beaten to death on here, but I cannot seem to get any straight 100% credible answer:
Were the third generation metal timing chain tensioners factory installed on any X308 cars? If so, from which date/VIN? If not, at least I'll know!
Thank you.
Thank you.
test point
close
- Join DateMar 2008
- LocationEllijay
Liked:1,116 Times in 935 Posts
All AJ27 ENGINES assembled after August 13, 2001 contained the metal tensioners. While there may have been a short pipeline interval between engine assembly and vehicle assembly anything after August '01 most likely had the later tensioners.
If you fall into that narrow window of late August based on the vehicle assembly date found on the driver 'B' Column it would be best to ask your friendly local Jaguar dealer to produce your build sheet based on the VIN. The engine assembly date is encoded into the engine serial number (yymmddhhmm).
Straight enough?
Straight enough?
And jaguar considers this a maintenance wearable item, total bs.
There should never be plastic or nylon inside an engine.
On Fords, the timing chain tensioner guides would strip of the nylon plastic, pieces would get inside the engine, cause rod knock and engine failure from clogging up the oil pump as well.
But in small claims court, that would not fly.
The above referenced date is correct,.......however. My cat is down (see my post) due to the loose chain on the second generation tensioner. When I bought the car, the seller claimed that "all important updates" were performed, and produced the receipt that showed the replacement of the tensioners. She ran beautifully (without ANY rattle), and I was too confident (and maybe lazy) to open her up and check.
The ONLY way to know for sure, is to open her up and check. When one is changing the spark plugs, half the work is already done. Few more bolts, and the cam cover comes off. Visual inspection is the ONLY sure thing.
Many people were in the situation I am in today. I know better, than letting this happen. Feel like standing in front of the mirror, and slaping myself multiple times!
OPEN IT UP! Look, and replace if necessary. All you need is 7mm and 10mm sockets. Takes about 10 minutes to unbolt the cam cover.
test point
close
- Join DateMar 2008
- LocationEllijay
Many of the early cars had the tensioners replaced with the external spring assisted plastic tensioners between their introduction sometime in '99 and the metal ones in '01. The plastic bodies and chain slippers just as reliably fail but the spring tension masks the chain rattle often reported as a warning. Therefore, I consider the spring assisted ones even more dangerous that the first generation.
The spring assisted 2nd generation ones were sold from stock and places like eBay as recently as a couple years ago so the fact that a car's tensioners were replaced within the last few years is no guarantee that it was with metal.
i agree totally you need to take cam cover off....and see for yourself......the use of plastic tensioners is not just a "jaguar"oversight....many cars from the same period used plastic....hard to believe you wonder just how much....money are they saving with this practice?nor does it sound like an elegant engineering solution for keeping things together.
I can take it a step further as this very problem....hit me on my maxi-scooter....and no metal replacements available (need two).....the difference being if your off on the sprocket even one link....the ecu shuts down the scooter............preventing further damage.....with the jag...maybe not so lucky.
sparkenzap
close
- Join DateNov 2007
- Locationatlanta ga
Liked:1,068 Times in 870 Posts
The date given is NOT the automobile build date, but rather, the engine build date. The engine seriel number decodes to the build date and time.
...I decoded my VIN and also found my build date (January 2001). I know I have the plastic secondary tensioners unless they were replaced by the PO. So, I'll order a set and have them replaced. Since it appears a specialty tool set is required to do the job, I imagine I will try to find an independent Jaguar shop somewhere to do the job since purchasing a tool set for use by a local shop makes no sense to me.
Thanks for all the information.
Since we are both in SoCal mountains, I'll give you a neighborly advice.Originally Posted by Huntervision
...I decoded my VIN and also found my build date (January 2001). I know I have the plastic secondary tensioners unless they were replaced by the PO. So, I'll order a set and have them replaced. Since it appears a specialty tool set is required to do the job, I imagine I will try to find and independent Jaguar shop somewhere to do the job since purchasing a tool set for use by a local shop makes no sense to me.Thanks for all the information.
Go on Ebay, and look for Christopher's Foreign Autoparts. They have a complete kit (which I purchased about 20 min ago for $299), and they also have a video showing how to do it. The kit includes valve cover gaskets, metal tensioners with bolts, and two secondary chains that have master links in them. The stuff can be purchased cheaper in pieces elsewhere, but one has to drive, and spend time looking for it. To me,.....three bills are well worth it, and I don't have spend any time on the phone, or in traffic.
Heck, since we are neighbors, you could drive to my ranch, and we can do them both at the same time!
plums
close
- Join DateFeb 2011
- Locationon-the-edge
Liked:2,201 Times in 1,633 Posts
Quote:
In that particular circumstance where you relied on a positive statement by the seller to your detriment, you would have legal recourse. If you wanted to bother and could prove that the receipt was shown to you.Originally Posted by danielsand
Just a thought.
Quote:
Just a thought.
I still have the receipt. AND I am an attorney by profession. However,......at the time of the purchase I did not know that there are three generations of tensioners in these cars! I've heard (from my mechanic) that in order for these cars to be worry free (like ANY machinery ever is!), certain things need to be done. One of them was "secondary timing chain tensioner upgrade". They were upgraded. From the original plastic ones, to the plastic ones with an external spring. They are not metal. Seller didn't mispresent anything. I doubt HE knew what generation tensioners were installed. The receipt simply says "timing chain tensioners replaced". Nothing else,...... and NO recourse.Originally Posted by plums
In that particular circumstance where you relied on a positive statement by the seller to your detriment, you would have legal recourse. If you wanted to bother and could prove that the receipt was shown to you.Just a thought.
I was telling the OP, not to relay on the paperwork (no matter how descriptive it might be), but to open the covers and look. And I should've done the same a year ago. Looks like I got lucky, and the whole fiasco will cost me only 300 (it would cost the same if I performed the upgrade before the failure) which I consider the "dinner money". But I learned!
Since I plan to buy the Range Rover, I think I should join the forum BEFORE I buy it, and learn as much as I can. I fall in love (cars, women, whatever), and THEN I do my "research"! A$$backwards.
motorcarman
close
- Join DateDec 2009
- LocationWise County,TX
Liked:9,640 Times in 5,765 Posts
I installed MANY MANY second GEN tensioners. We were issued TSB 303-30 and the spring added seemed to be the answer to 'RATTLE AT STARTUP'.
Yes the second Gen tensioners fail the same way the first Gen ones fail.
It was early in the 4.0 evolution.
bob gauff
bob gauff
Uh huh, I think that is the same vendor I saw. So, I wonder how difficult the change over on the chains would be? I have not seen any threads on failed chains. OTOH, it seems logical to change them if you are in there. I saw the videos. The ones I saw were two describing the change also of the primaries and water pump. However, I did come across a UTube video of the tensioners themselves being replaced.Originally Posted by danielsand
Since we are both in SoCal mountains, I'll give you a neighborly advice.Go on Ebay, and look for Christopher's Foreign Autoparts. They have a complete kit (which I purchased about 20 min ago for $299), and they also have a video showing how to do it. The kit includes valve cover gaskets, metal tensioners with bolts, and two secondary chains that have master links in them. The stuff can be purchased cheaper in pieces elsewhere, but one has to drive, and spend time looking for it. To me,.....three bills are well worth it, and I don't have spend any time on the phone, or in traffic.
I don't know if I have the confidence to tackle the job DYI, but I'll send you a PM or email.
RJ237
close
- Join DateDec 2010
- LocationDouglasville Ga.
Liked:2,924 Times in 2,317 Posts
I can't refer to any particular thread, but I recall seeing some posts in the past couple of years warning that chains with master links failed.
Quote:
Totally agreed. It IS the engine code you need. And yes the magic date is August 13, 2001 at midnight. Thus engine code: 0108130000.Originally Posted by sparkenzap
Last four digits represents the time of day in military time as indicated above. Thus 0000 = Midnight.
There are more than a few documented cases where the car build date (on the door column) is September 2001 BUT with an engine that was manufactured before the cut off date. I know, I got one.
A Jaguar dealer will usually give you the engine build date (engine code/number) over the phone if you give them your VIN. But you also need to be aware that some of the engines in these Jaguars have been switched out. So there can be a case of a failed engine (for any reason) that has an engine that may be months, if not years, older than the vehicle production date.
RJ237
close
- Join DateDec 2010
My comment on chains was perhaps too negative. I owned and worked on Alfas back in the 60's. They had chains with master links and a slip on keeper, just like bicycle chains, and I never heard of a failure. So, it's not like you can't make a good chain with a master link
MFoncerrada8
close
- Join DateSep 2013
- LocationWashington DC
Liked:44 Times in 30 Posts
Quote:
LOL....don't we all!Originally Posted by danielsand
... I fall in love (cars, women, whatever), and THEN I do my "research"! A$$backwards.
Quote:
I went all over looking for examples of failures and all I could find was SAAB and some on modified Corvettes and the discussion was that they were not related to the chain but aftermarket dampers et al. Lots of talk re: motorcycles/ATV's and jet skis, but nothing re master link failure.Originally Posted by RJ237
OK, so I think I'm getting WAY too immersed in this and just need to get the da*mn things updated!. If chains are easy, I'll do those too. If not, tensioners have first priority.
I'm sorry I know this has been beat to DEATH (isnt there a gif for that somewhere??) but there's a deal that just popped up in Socal on a XJ8. He's had the tranny rebuild but as the second owner wasnt sure about the tensioner. I found this:
In their Technical Service Bulletin No. X303-68 of February 2005, titled “Rattle From Engine on Start-up and Idle,” Jaguar states:
This Technical Bulletin has been issued to address customer concerns of a rattle emanating from the engine on start-up and idle.
Cause: Failure of a primary or secondary timing chain tensioner.
Should a customer express concern, and the fault has been confirmed as a timing chain tensioner, new primary or secondary timing chain tensioners must be installed.
Engines subject to this problem include XJ8/XJR engines with the last six digits of their VIN numbers between 812256-F41862, and XK8/XKR engines with the last six digits of their VIN numbers between 001001-A24195.
Ok that being said is there any way to know for sure if the tensioner has been replaced? Carfax? Dealer history? Or just crack it up and check?
Thanks guys. This n00b owes y'all drinks for sure!
test point
close
- Join DateMar 2008
- LocationEllijay
Welcome to the forum!
The ONLY way to be sure is to remove BOTH valve covers. There has been more than one post on finding only one tensioner replaced.
