throttle body malfunction
Old Jun 23, 2019 | 07:51 AM
quartetchiang's Avatar
Default throttle body malfunction
Has anyone seen a butterfly valve actually becoming a butterfly like this? This is only with key at ignition stage two. Car is 2000 XJR.
https://www.facebook.com/paul.cp.chiang/videos/10157134730358280/?epa=SEARCH_BOX
Old Jun 23, 2019 | 07:54 AM
well it seems the FB link does not work, and I can't seem to upload MP4 here. The symptom is that the butterfly valve of the TB would constantly flip rapidly, and making a rapid chatter noise. Of course the car is in-operatable.
Old Jun 23, 2019 | 08:35 AM
Highhorse's Avatar
You can do a video and create a link...file sizes are limited or folks would be putting all sorts of junk on here.
Attached below is a pdf for review. I would try a hard reset to see if that clears it also.
File Type: pdf
Old Jun 23, 2019 | 10:10 AM
Okay guys, here's the Youtube link:
Old Jun 23, 2019 | 04:38 PM
Highhorse's Avatar
That's an electric salt shaker....then back to post 3
Old Jun 23, 2019 | 04:50 PM
Sean B's Avatar
Perform a hard reset.
Then report back here...
Old Jun 24, 2019 | 11:03 AM
Alright guys, culprit found!! Apparently it's the TPS connector going bad. It looked fine from the outside, but inside, the plastic seats of the female sockets had multiple collapses, thus compromising signal transmission! Hope this information is of some value to all.
Stounedi
21
Dec 23, 2017 06:33 AM
bullittandy
Sep 8, 2016 02:31 PM
juha_teuvonnen
Dec 17, 2014 09:35 PM
sws805
Jan 24, 2013 10:58 AM
rvaha
Feb 4, 2012 05:00 PM
