Throttle body removal
Old Aug 26, 2016 | 09:44 AM
yeldogt's Avatar
Default Throttle body removal
Can anyone direct me to the removal procedure?
It looks like only a few bolts need to come off -- I'm wondering about the throttle cable .. any other complications.
Also -- I want to order a new gasket between the Tbody and intake -- anything else?
I have been getting the failsafe message too often recently -- everything points to the pedal position sensor. I may drive the car over to the dealer and have them pull all the codes. I'm getting all manner of warning - it may be best to see if any are coming from the brake switch/ instrument panel -- or ABS pump/module.
Old Aug 26, 2016 | 10:14 AM
avern1's Avatar
It would be most helpful if we knew what Jaguar your working on. Once we know then we can advise. I have had the throttle body off my 1998 XJ8 a couple of times.
Old Aug 26, 2016 | 10:36 AM
vdpnyc's Avatar
It's been 5 years since I did it, twice, (first replacement was defective) and it was easy, lots of plugs and hoses but all obvious as to what to do and relatively easy to access.
I think there was one connector or hose clamp or something on the bottom side that was tricky but otherwise an easy job.
Old Aug 26, 2016 | 10:37 AM
yeldogt's Avatar
2002 XJR
Old Aug 26, 2016 | 05:30 PM
nilanium's Avatar
this includes TB removal for the xjr https://www.jaguarforums.com/forum/x...f-files-58889/
Old Aug 28, 2016 | 11:39 AM
yeldogt's Avatar
Thanks -- I'm going to tackle this week.
34by151
May 6, 2024 12:20 PM
Apr 17, 2019 04:33 PM
dannio636
Apr 6, 2016 10:59 AM
Aug 17, 2006 10:31 PM
Aug 17, 2006 06:53 PM
