throttle surge, usually when warm.
Old Nov 14, 2009 | 12:39 PM
goldencharriot's Avatar
Default throttle surge, usually when warm.
Hi,
My 99 XJ8, 150k miles, is surging under light throttle, low speed or freeway. I've cleaned the throttle body, changed the plugs, and couldn't find any blocks in the breather system. Rarely the idle dips also. It isn't showing any engine codes (only traction control system fault).
Any help with this would be appreciated before I start throwing parts at it. Thanks in advance.
Old Aug 29, 2012 | 03:32 PM
hm1's Avatar
hm1
Any luck with this?? I'm having the exact same thing...
Old Aug 31, 2012 | 08:31 AM
Dinger's Avatar
Have a look at your air ducting from the air intake box to the throttle body. The smallest crack or pinhole anywhere will cause this symptom. I had it when my engine would rev up and down without any input from me. I found a very small crack in the air intake trunking, taped it up and job done !
Old Aug 31, 2012 | 10:52 AM
hm1's Avatar
hm1
Mine looks new, but I will take apart and really inspect it
Old Sep 6, 2012 | 03:39 PM
In my case it turned out to be corrosion on the throttle body harness plug. You couldn't see it, but when I cleaned it (very thoroughly with electrical parts cleaner) and put dielectric grease on it it fixed the problem permanently. I also found a vacuum leak under the throttle body. There's a plastic hose that comes into the intake manifold on the passenger side that had cracked. I'm not exactly sure which thing fixed it, I can't remember. If you havn't already it's not a bad idea to go over your entire vacuum system, these cars are prone to leaks and are sensitive to them.
Hope that helps!
jimforrest (uk)
Feb 28, 2019 06:42 PM
tomkilner
Oct 9, 2015 07:10 AM
inactualis
Oct 2, 2015 11:13 AM
Nigels420G
Mark V - X 420G
Sep 27, 2015 03:48 PM
