Time to say goodbye ?
Its a $100 part, the cost will be capturing your A/C coolant (if you have any left), and/or replenishing it. Then after getting that cost totaled (which shouldn't be too bad), its up to you to determine the value of doing it. Just make sure a qualified person does the air work.
All shops have a labor rate to quote with. Just go to a brand name place and ask, they should even print you out the quote. Usually an inde' shop will get you a better price and allow you to buy the parts. I don't know national repair shops that will do that.
Here's a Bing search quote from repairpal.com....
The average cost for AC evaporator replacement is between $836 and $1,078. Labor costs are estimated between $513 and $648 while parts are priced between $323 and $431. This range does not include taxes and fees, and does not factor in your unique location.
