99 XJ8 upstream O2 sensor removal
Old Mar 21, 2021 | 01:46 PM
studeb's Avatar
Default 99 XJ8 upstream O2 sensor removal
Hi,
Code 1647 showed up, the dreaded upstream bank 2 o2 sensor is dead. Live data shows 0 volts from the sensor. So i ordered anew one and am trying to get the old one out.
Drain and remove the overflow tank, and the heat shield screws. Easy peasy.
According to posts from TXE36 and Highhorse, the shield should be able to move out of the way to access the sensor.
So far i have been unable to get it moved enough to get the sensor. It will not slide down far, and will not rotate very far. i tried pulling it up , got is as far and the camshaft housing, but would not go further.
People say "move towards transmission" which would be across the car, that does not work.
Does anyone have any tips?
Old Mar 21, 2021 | 01:48 PM
studeb's Avatar
Default Pixs
As a thread is useless without pics, here is what I am looking at, is there more to remove?
Old Mar 21, 2021 | 02:07 PM
studeb's Avatar
Okay, never mind.
I managed to pull the shield up and out.
Sensor is now soaking in penetrant.
Hopefully i can remember how to get it back in again!
Old Mar 21, 2021 | 05:58 PM
Highhorse's Avatar
From the "How-To" section at the top of the forum... https://www.jaguarforums.com/forum/x...cement-195018/
Old Mar 21, 2021 | 06:51 PM
Addicted2boost's Avatar
Remove this hose clamp and pull the hose off. Pull this hose up and out of the way. You’ll have some coolant spill out then but you’ll have a lot more room. BE CAREFUL AS THE NIPPLE OFF THIS VALVE COULD BREAK. Ask me how I know.
Old Mar 22, 2021 | 12:13 PM
studeb's Avatar
Hi,i managed to get it done without removing that hose, but I agree it would be easier with more room. Idle is much better now.
thanks for the support!
X300exec
Feb 19, 2021 01:08 PM
David SD
Jul 6, 2015 04:41 PM
Steve_Jaggar
Apr 22, 2014 12:15 PM
robin48
Apr 18, 2014 09:34 AM
Crosbo
Mar 25, 2010 09:01 PM
