Timing Chain too tight?
Old Dec 3, 2020 | 09:41 PM
Desertdawg's Avatar
Default Timing Chain too tight?
No Timing Chain slop. I am installing new chains and tensioners on my XJ8 and don't have any chain tension to adjust. It's so tight I'm afraid something will break when I start it. The chains are same length. Tensioners have thicker plastic runners than the old broken ones. Am I missing something?
Old Dec 3, 2020 | 11:54 PM
xalty's Avatar
i’d start it and see. if you’re gonna do it again ditch the new chain, no point in putting questionable a quality replacement if the old one doesn’t have much wear
Old Dec 4, 2020 | 04:25 AM
M. Stojanovic's Avatar
Which chains and tensioners? Primary, secondary...
Old Dec 4, 2020 | 01:24 PM
Kroeger’s Jag's Avatar
I got mine from Christopher’s foreign car parts, and my primary chains were very tight as well I couldn’t even get a shim in between the tensioner and the guide but I asked my go to mechanic and he said as long as it’s tight you should be good and mine are fine and I’ve put on a 1000 miles since but I don’t know why they were that way and I don’t wanna tell you it’ll be fine because idk if yours will be. Make sure you have the CRANKshaft sprockets on correctly as well as I forgot to check that when I did mine.
Old Dec 4, 2020 | 02:06 PM
Desertdawg's Avatar
Thank you very much! I even counted the links (53) to be sure the chains were same as old ones. haha
Old Dec 4, 2020 | 02:42 PM
Desertdawg's Avatar
Bought off Ebay, made in Japan (my bad?). The kit was $299 with chains, tensioners, and seals.
Old Dec 4, 2020 | 02:47 PM
Desertdawg's Avatar
Supplier was europeanautoco .
Old Dec 4, 2020 | 03:12 PM
Highhorse's Avatar
Mine were so tight, I had to sequentially put on the gears. One couldn't be more than a mm more than the other or it bound. Then I had zero release from the tensioners and guides when I pulled the pins. That was 6-7 yrs ago now.
Andreas Schmieg
May 8, 2021 06:16 PM
VivaJag
Feb 12, 2020 04:34 AM
Aleather
Jul 26, 2017 09:54 AM
fR144
Feb 21, 2014 09:49 AM
TN8Shooter
Sep 30, 2012 09:16 PM
