Timing chain tools
Old Jul 1, 2018 | 08:43 AM
Sacho's Avatar
Default Timing chain tools
Hi all, looking for all the correct tools needed for the entire replacement on a 2000 xjr timing tensioners. Thanks anyone wanting to rent , sell or borrow. Very appreciated
Old Jul 1, 2018 | 10:36 AM
Carnival Kid's Avatar
If you can find someone close to you who you can borrow the tools from, that would be great (you don't say exactly where you are located, there are many Marlboros), that would be ideal, but if not, you will need to purchase two tool sets.
The camshaft/tensioner/crank positioning alignment set is available from several online sources for $50 or less. Here is just one example.
Amazon Amazon
And the more expensive crank holding and harmonic balancer puller set is available here, at a pretty decent price.
Amazon Amazon
You can purchase all that is needed for less than $200.00
Old Jul 3, 2018 | 07:48 AM
Robert Laughton's Avatar
When I did the tensioners on my R years ago, I recall that the R required a different pully puller. I think the pully and damper were one piece - different from NA.
I wonder if that tool on Amazon will do both.
Rob
popeye68
Feb 2, 2014 06:54 AM
slanham
General Tech Help
Feb 1, 2014 06:34 PM
97Aggie
Jan 13, 2009 08:11 PM
