Timing Chains
Old Sep 9, 2015 | 01:59 PM
Dicque's Avatar
Default Timing Chains
Doing a complete job. Replacing timing chains, tensioners and guides. biggest hurdle is the harmonic balance bolt today. But will get it done tomorrow and pass on any suggestions.
2000-2004 4.0 VDP
Last edited by Dicque; Sep 9, 2015 at 02:01 PM. Reason: did not include model and engine
Old Sep 9, 2015 | 02:56 PM
King Charles's Avatar
https://www.jaguarforums.com/forum/x...ners-how-4747/
Old Sep 12, 2015 | 07:47 AM
diablobuck's Avatar
2000-2004 4.0 VDP
Pardon me if my question is either redundant or juvenile. Sadly, I know very little about car mechanics. Is it SOP to replace the water pump when changing the timing chain?
Thanks,
Shawn
Old Sep 12, 2015 | 08:48 AM
xjay8's Avatar
Thanks,
Shawn
It's not a given Shawn...only if it turns out to be bad....which is not all that often.
There is a bit of anallity concerning these water pumps and it is usually down to lack of maintenance in flushing and replacing the proper coolant at the prescribed schedule ;o]
Old Sep 12, 2015 | 10:34 AM
sparkenzap's Avatar
And, the answer to whether you should partially depends on the MY of your car. The early ones had a design problem leading to early failure. So, is your car really a condo of 5 years? If so, which year is the engine?
RoyLittle0
May 25, 2023 02:38 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Dicque
Sep 19, 2015 12:53 PM
Bowman
Sep 15, 2015 06:54 AM
Dicque
Sep 4, 2015 12:50 PM
