Towbar issue Please help
Old May 2, 2015 | 02:06 PM
ithica271's Avatar
Default Towbar issue Please help
Hi all I'm new here, PLEASE can anyone help me. I have a x308 xjr MY2000 which had a genuine Jaguar tow bar on, which I had removed by my so called, local garage which specialize in jaguars. Once they removed it the turn signal indicator in the dash now flashes and beeps twice as fast. The turn signals around the car flash as normal. This is driving me mad.
Any advice will be greatly appreciated
ithica 271
Old May 3, 2015 | 06:13 AM
andrew lowe's Avatar
Try disconnecting the battery for 5 mins or so.
If that do not work try doing a hard reset.
Old May 3, 2015 | 08:12 AM
ithica271's Avatar
Hi Andrew,
Thanks for the info the battery was disconnected last week when the car was in the garage for an other issue, you mentioned a HARD RESET ?,Is that when you remove the negative cable from the battery and touch it to the positive cable which is still connected to the battery for a couple of seconds and then reconnected the negative cable.
Do you remove the negative cable with the ignition off, touch the positive terminal with the ignition on then turn the ignition off and reconnect the negative cable to the battery.
Will this effect the mileage registered on the cars instruments ?
regards
ithica271
Old May 3, 2015 | 09:36 AM
Mark SF's Avatar
I wonder how they removed the trailer wiring. In the fuse box in the trunk, there is a 14 pin connector for trailer wiring. The plug includes a link that tells the car that a hitch is present. You might want to see if they unplugged that connector. I suspect they just tied the cabling and trailer plug out of the way.
Old May 3, 2015 | 10:10 AM
retromotors's Avatar
Originally Posted by ithica271
Do you remove the negative cable with the ignition off, touch the positive terminal with the ignition on then turn the ignition off and reconnect the negative cable to the battery.....
Will this effect the mileage registered on the cars instruments ?....
No ... hard reset is performed with ignition switch off at all times.
I would guess that connecting the battery into the system with the ignition on could cause some serious problems.
No, accumulated mileage will not be affected, with the exception of probably resetting the A and B trip odometers.
edit: re your "hard reset ....couple of seconds", I think the current wisdom is to touch cables for 15 - 30 seconds.
Old May 3, 2015 | 12:56 PM
ithica271's Avatar
All associated wiring for the tow bar has been removed, done a hard reset as suggested, when all back together, I tested the system indicator in the dash, flashed and beeps as it should for about 8-10 seconds then resumed to flash and bleep twice as fast.
Any other advice would be appreciated.
I'm new on here just had the car(x308xjr) for a couple of months after wanting one for 12 yrs. (best car I have ever owned)
Regards
Ithica271
Old May 3, 2015 | 06:00 PM
D. Fite's Avatar
Could be the flasher relay. Sometimes when a hitch is installed they will plug in a heavy duty flasher relay to handle the extra load of trailer lights.
Dave
Old May 4, 2015 | 04:54 AM
plums's Avatar
With only 3 posts, can't send you a PM.
But any interest in getting rid of the towbar?
Old May 4, 2015 | 05:32 AM
ithica271's Avatar
Sorry Plums, but the towbar has already been sold,
Old May 4, 2015 | 05:57 AM
plums's Avatar
Not surprised
They look to fit very well unlike that add-ons on this side of the pond.
Old May 4, 2015 | 01:06 PM
Mark SF's Avatar
I just put a Curt on, seems to work just fine. Did you have problems with one?
Old May 4, 2015 | 06:29 PM
deancantrell's Avatar
A bad ground will cause the turn signal to flash that way.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
carelm
Sep 5, 2015 01:13 AM
