Traction Control
Old Apr 8, 2011 | 05:23 PM
TN8Shooter's Avatar
Default Traction Control
Hey All,
I have tried everything that I know (not much) to get the traction control button to work. I want the ability to turn it off, but as of now I cannot.
I've checked all the appropriate fuses
Checked to make sure the button is working
Corrected the abs malfunction issue
The control will not turn off via the button.
Anyone else run into this problem?
Old Apr 8, 2011 | 05:54 PM
Sean B's Avatar
Hi what was your abs issue? trac and abs are linked, have you tried a hard reset?
Old Apr 8, 2011 | 10:26 PM
TN8Shooter's Avatar
The abs issue was related to the 2 solder joints on the motor leads. I corrected that issue, but I'm not sure if maybe the module itself was bad.
If you're referring to touching the battery leads together for a hard reset I have done that.
Old Apr 10, 2011 | 05:57 AM
jimlombardi's Avatar
Hi
Are there any warning lights or messages being displayed? If yes, then what warning lights are on and what are the warning messages?
Jim Lombardi
Old Apr 10, 2011 | 08:26 PM
TN8Shooter's Avatar
Originally Posted by jimlombardi
Hi
Jim Lombardi
There are no lights, nor are there any messages.
bdboyle
Sep 16, 2019 05:58 PM
mrplow58
Sep 30, 2015 08:56 AM
Old_Doc
Sep 29, 2015 03:43 PM
42Ajd
Sep 26, 2015 07:04 PM
