Tranny issue
Old Apr 13, 2012 | 08:46 PM
Flajagmann's Avatar
Default Tranny issue
I have a 2000 xj8. The tranny is very slow the shift into fourth gear. In fact I need to start of in 3 because starting off in D is an issue with shifting out og first gear
Where should I look first to fix the issue
Thx
Old Apr 14, 2012 | 05:08 AM
Sean B's Avatar
I'm afraid that isn't good news. This sounds like an A drum failure, can you give details of how the fault has come about? Slipping in gears? odd noises? Slow selection can also be low fluid level. When was the gearbox last serviced?
I'd suggest getting it looked at by a trans specialist.
Old Apr 14, 2012 | 01:11 PM
avt007's Avatar
That is strange one. The A drum is used for first through fourth gear, so that may not be the problem. Fluid level and proper diagnosis is the way to go.
Old Apr 14, 2012 | 07:52 PM
Flajagmann's Avatar
Default Tranny
I will check fluid level. I thought they were sealed units. Where do I find the filler tube for the tranny fluid. Does it take normal tax
Thx
Old Apr 15, 2012 | 12:50 AM
avt007's Avatar
There is no dipstick. Do a search for 5HP24 and you'll find info on fluid checking.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
tomsjag
Jun 10, 2023 10:02 AM
neruda
Oct 18, 2015 01:19 PM
ahunt4
Sep 14, 2015 08:17 PM
