Transmission Fault-2001 XJ8L
Old Nov 13, 2009 | 05:48 PM
GeorgiaXJ8's Avatar
Default Transmission Fault-2001 XJ8L
My Jag does fine in "D", but when I put it in manual mode, it immediately gives a transmission fault and shows restricted performance. Any ideas on this problem?
Old Nov 15, 2009 | 01:35 PM
RealmCenter's Avatar
Cable adjustment issue, if it's not an R then it doesn't have a dual linear switch that also needs to be adjusted. Proper adjustment of the trans cable can be tricky buisness. There are two big jamb nuts that hold the cable to the J-gate. I do them by feel, it took a long time to get the hang of it. If the cable is adjusted correctly and there is still an issue deeper investigation would be required.
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
Poet
Oct 2, 2015 09:00 AM
JTC3400
Sep 29, 2015 05:03 PM
Old_Doc
Sep 29, 2015 03:43 PM
