Transmission fluid leak
Old 01-31-2022, 06:58 PM
pcolapacker's Avatar
Default Transmission fluid leak
Spotted a spot on the concrete about the size of a small plate after sitting all day. Drip is coming off the middle of the front sway bar. Haven't had time to put up on the lift to check. Suggestions of where to look. Transmission cooler lines?
Old 01-31-2022, 07:05 PM
Addicted2boost's Avatar
If you’re sure it’s ATF, maybe a power steering fluid leak as a possibility?? Either way, just try to find out where it’s coming from first.
Old 01-31-2022, 08:18 PM
nilanium's Avatar
On the PS note, my PS return line (goes from steering rack to ps cooler) has a very slow leak at the coupling that's not far from the front sway bar. Worth a look?
Old 01-31-2022, 08:37 PM
Glad you mentioned that Nilanium. The same area on my daughters 98’ XJR is also leaking there. Thanks for the reminder.
Old 01-31-2022, 09:33 PM
ATF for sure, reddish. I checked the color of my power steering fluid, kind of a yellow/tan.
khsjsilver
07-10-2019 01:51 PM
itsvic
07-31-2013 07:17 PM
usmc1211
03-03-2013 10:16 PM
climberman
05-09-2011 09:46 PM
djpage
31
04-17-2011 08:40 AM
Quick Reply: Transmission fluid leak
