Transmission life
Old Apr 27, 2015 | 01:20 PM
Pantherman2's Avatar
Exclamation Transmission life
How long does the transmission last?
I have been told that it lasts till about 100,000 miles and then needs rebuild.
Does it cause any problems using the shifter or sport mode all the time?
I was told that it can cause problems, which does not seem right if you it shifting with in the limits and not powering the car too much.
Old Apr 27, 2015 | 02:02 PM
badger2196's Avatar
Which car? The XJ8 and XJR have different transmissions.
Old Apr 28, 2015 | 08:14 AM
Default Transmission
Sorry! Yes that would help I have a 1998 XJ8
Old Apr 28, 2015 | 10:39 AM
badger2196's Avatar
The XJ8 has the ZF5HP24 transmission which can suffer from A drum failures due to pressure spikes caused by the pressure regulator valve. There is an updated PRV that can be fitted to prevent this issue (part no 1058-327-030).
This problem seems to show up in the 60 - 100K mile range.
Old Apr 28, 2015 | 10:51 AM
bdboyle's Avatar
You have a ZF 5HP24. There is a known issue with the high pressure valve body in the tranny; the body scores, the piston hangs, and a pressure pulse overstresses the input clutch basket.
For what it's worth, BMWs and Audi with the same box have the same issues, so it's not Jag-specific.
Installing a rebuilt and updated valve body may forestall or head off the issue; but at that point, installing a reman with updated parts is not that expensive considering.
Yes there is an issue; but it's not life threatening in and of itself. It can be dealt with (as many, including me, have done). Now, whether investing 2500-3000 in a tranny (for the overhauled unit, rip and replace labor) is worth it in a car that's only worth 4-5K is a decision only you can make, though.
Jandreu
Jun 30, 2022 03:10 PM
ryan_border
Dec 23, 2015 04:27 PM
mrplow58
Sep 15, 2015 09:58 PM
chatmanx
Sep 11, 2015 07:17 PM
mrplow58
Sep 9, 2015 11:27 AM
